Fireman 123
- May 14, 2011
- 42
- 358
I have a 6.5 HP Duraforce powered mower that I have been going thru and tuning up. I've taken apart the carb and cleaned it, and changed the spark plug.
After buying it ($20) I brought it home and started it, but it had a substantial sputter, and spit old gas out of the above deck muffler.
Today, after cleaning and putting the carb back on, the engine run smooth, but still an exhaust sputter. I took the cover off the exhaust tube housing under the deck and a bunch of old gas spilled out of it. The tube itself had a little carbon build up, but wasn't blocked any.
After cleaning that mess up and putting the tube back and cover on, it still has the sputter and smokes some. I always use LB oil 32/1. I think all of this is pointing to bad rings, hence the smoke, and gas getting by into the exhaust. If there's anyone that can lend any expertise I'd appreciate it.
