Hi Guys, I am a newby here. This 550EX TB110 starts with Carb Cleaner and then runs fine. If I shut it off while cutting the grass I have to use fluid to start it again. It seems like a specific problem. I am hoping to fix this rather than take it to a shop.
I had to patch a hole in the gas tank. i plan on cleaning out the tank and cleaning out the carb, just wondering if there is something in particular that would cause this situation.
Thanks,
John Q
Thanks,
John Q
