46"super bronco upper deck belt is loose
ba_50
It has a new belt on but when in off position, it has about 2 1/2" off slack and comes off the pulley.
The idler pulley is going back and forth.
There is a belt diagram and it should be good there.
What should I do?
Thanks
Firstly the belt should go slack in the off position.
There should be guides that prevent it falling off.
For any more information we really need the model numbers from the tag under the set.
shiftsuper175607
What should I do?
_____________________________
Comes off the pulley...which pulley?
When was the "new" belt put on?
Who put it on?
has it worked since the new belt was put on?
1)Belt is on the wrong side of an idler pulley...belt is routed wrong.
2)Wrong belt
ba_50
It is a 13ax60kh011
It comes off the left double pulley spindle.
shiftsuper175607
It is a 13ax60kh011
Who put it on?
_______________________________________
2)Wrong belt
ba_50
Pictures of pto on and off.
The belt was on the wrong side of the gold bolt in the center. Shouldn't matter concerning the slack.
With pto on it will be snug bout hits the inside of the pulley cover.
ba_50
Due to a combination of errors on my part, the deck was pinned farter back and problem solve.
Even though I am not mechanically inclined, I should have fixed it sooner.
shiftsuper175607
Congrats, thanks for letting us know you are back up and mowing.
ba_50
Actually I have the same problem with the belt coming off the far left pulley. With the deck all the way back the blades turn with the pto off. If next hole forward it is to loose and comes off when pto turned off.
ba_50
By moving the cover I got the keeper closer to the pulley. By taking moving the pto slowly it stays on. Will see.
