stryker6040
- May 7, 2019
- 1
- 6
Hello all, hoping you can point me in the right direction. I have a 27hp v twin on my hasqvarna garden tractor that has begun to run rough while the PTO is engaged.
From the testing I have done so far the cylinder on the passenger side of the motor when sitting in the seat has spark but is not firing when doing the test of removing one wire at a time to see if the engine continues to run. When i remove this side the engine does not change but when I pull the drivers side off the engine dies leading me to believe this is my issue.
Ive tried swapping plugs with no change and both plugs are showing a good blue spark when tested.
Ive removed the valve cover on the dead side and the valves appearing to be moving freely with no excessive slop, but I havent checked the lash yet.
Any suggestions to check?
