It is a forum where people come for help and those with answers provide help. Do I know it all, definitely not, but a have rebuilt well over 700 engines and think I can speak from experience. You say that you think you can fix your problem for about $40. Let me know where my thinking is wrong. You have a Briggs V-Twin engine model 445777. This engine has two cylinders. That means two sets of rings at $31.00 each. Two head gaskets at $6.00 each. Two valve cover gaskets at $6.00 each. Breather gasket at $3.00. Sump gasket at $15.00. Two intake manifold gaskets at $2.00 each. Two exhaust manifold gaskets at $2.00 each. $5.00 for oil. If you are going to do it right parts alone cost more than $100.00, at my rough prices and I'm sure I forgot something. You don't know what is wrong, so let's just throw some parts at it and see what happens. Could be one bad set of rings or two, a bad piston which run $65.00, any one four valves which run about $18.00 each, bad valve guides, etc. You don't even think you should have someone take some measurements. As a member of this forum I feel that I should not only help others solve problems, but also warn them when it may be better to leave it to the pros. I could be wrong and you might have a lot of experience in doing large OHV engines, but by your post I doubt it. That's why I try to educate members that sometimes it's better not to try things and maybe save them some money. You probably hate me for my answer, but you are going to have to get in line, your not the only one. Lucky I have thick skin and I'm too stupid to worry about it.
