Honda Harnony Model 2103 (1995 manufacture) 13hp lawn mower tractor.
The axle is locked as if in "Park" with a car, and no gear selection will free them up.
The differential is working because if I raise the rear end, and turn one wheel, the opposite one rotates in the opposite direction, but both will not turn in the same direction.
The drive pulley appears disconnected from the axle (turning the pulley on the top of the transaxle doesn't cause the wheels to turn).
The gear shift lever moves the transmission gear shaft at the transaxle through all gear positions-just nothing changes.
Any ideas?
Bob
The mower shop described the mower as one of the mor complicated ones to work on, and wants $400 just to look at the machine, and says if it needs belts (it appears not to) it would be another $150, so for close to $1000 I'd rather buy another manufacturer's used/new one.
Any ideas?
Bob
