Results 1 to 3 of 3
  1. #1
    Join Date
    Oct 2019
    Posts
    4
    Location
    Tennessee
    Mower
    Hustler
    2006 Hustler Fastrax
    I have a hustler fastrax and used it for about 5 cuttings after purging the system due to a leak at the charge plate and then it would not purge so I bought a new plate, changed the filters and oil and it still will not move
  2. #2
    Join Date
    Apr 2019
    Posts
    11
    Location
    Tennessee
    Mower
    Exmark
    Re: 2006 Hustler Fastrax
    Quote Originally Posted by Bowils View Post
    the pump has a hex screw or bolt that requires removal to fill the until the fluid runs out, located at the inside top of the pump. then jack up the back wheels to purge the system. if you took off the bottom plate then you most likely have it on wrong, easy to do, trust me from experience and others in this forum turn the plate around. then purge the system.
  3. #3
    Join Date
    Oct 2019
    Posts
    4
    Location
    Tennessee
    Mower
    Hustler
    Quote Originally Posted by rick.kinney View Post
    The directions stated to install with the flat side of the plate towards the center of the frame and this matched the opposite side. The overflow was used and capped only after oil was exiting. Then went to the purge procedure and it still would not purge. In previous purges it would always whine when engaging until it was purged until the last time before I started the repair and it did not whine. This is still the case after the repair. It does not whine and barely makes a noise. I can get it to barely turn when engaged, but any pressure will stop it. Looking at buying a new Hydro-Gear unit, but not sure if the online sites are legitimate.
Similar Threads
  1. 2006 Hustler Fastrax
    By Bowils in forum Hustler Forum
    Last Post: 10-22-2019, 01:18 PM
  2. 2006 hustler mini zee / 52" / starter relay keeps burning out, loosing spark
    By Radioman in forum Small Engine & Mower Repair
    Last Post: 03-04-2018, 09:31 PM
  3. Should I buy a 2006 Hustler or a 2013 John Deere?
    By EricB in forum Mower & Equipment Buying & Pricing
    Last Post: 05-20-2013, 07:19 AM
  4. Hustler Turf Introduces the Hustler Extended Service Plan
    By Muhammad in forum Equipment News
    Last Post: 05-11-2013, 03:24 PM
  5. 2006 CC ZFORCE 50
    By SUREYARDS in forum Cub Cadet Forum
    Last Post: 04-17-2012, 07:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
