Results 1 to 10 of 10
  1. #1
    Join Date
    Aug 2019
    Posts
    Location
    New Jersey
    Mower
    Need hellp with little wire on snapper rer
    So I had to replace the throttle bracket on my snapper 13.5hp because the little nylon slide that holds the cable snapped...not too hard a job...got it back together and now the mower wont start...I think the problem is a thin black wire that comes out from under the flywheel shroud..need to know where it hooks up...is it a ground, or does it connect to the other two wires that are hooked up together on a stand alone stud mounted on a plastic insulator that mounts to the bracket. couldnt find any real diagrams on this.
  2. #2
    Join Date
    Jul 2013
    Posts
    5,198
    Location
    Georgia
    Mower
    2010 simplicity broadmoor 46" deck 20hp vanguard
    Re: Need hellp with little wire on snapper rer
    post your complete model number
  3. #3
    Join Date
    Aug 2019
    Posts
    Location
    New Jersey
    Mower
    Quote Originally Posted by mechanic mark View Post
    ;motor is 28M707 trasctor is 331414be
  4. #4
    1,000 Post Club
    Scrubcadet10's Avatar
    Join Date
    Sep 2017
    Posts
    1,138
    Location
    Conroe
    Mower
    CCltx1040,ryobi push w/ BS6.25 Poulan w/ a 4.5 horse BS, poulan w/ 799983 short block.
    Most likely likely it's the coil kill wire. But it still should start without it hooked up I believe. Pull the flywheel shroud and look.
    Is it bare copper wire on the end or does it have a connector of sorts?
    I know enough to be dangerous
  5. #5
    Join Date
    Aug 2019
    Posts
    Location
    New Jersey
    Mower
    Quote Originally Posted by Scrubcadet10 View Post
    there is a connector I have it hooked to ground
  6. #6
    1,000 Post Club
    Join Date
    Sep 2017
    Posts
    1,138
    Location
    Conroe
    Mower
    Now, will the engine turnover? OR nothing when you turn the key?
  7. #7
    Join Date
    Aug 2019
    Posts
    Location
    New Jersey
    Mower
    Engine will crank but not start even with starting fluid....only difference from a previous running engine is I replaced the throttle bracket and dont know where that skinniy black wire goes...it is a single strand copper wire.
  8. #8
    1,000 Post Club
    Join Date
    Sep 2017
    Posts
    1,138
    Location
    Conroe
    Mower
    Take off the blower/flywheel housing and trace the wire. To make sure its the coil kill wire
    IF it goes from the ignition coil straight to ground, you will not have spark.
  9. #9
    Join Date
    Nov 2014
    Posts
    12,750
    Location
    Australia
    Mower
    Victa slashers & Push , Rover Rancher II's, Cox ( several ) & White LT120 + GT 200
    You had it right at the end of your original post.
    It goes on the INSULATED post,
    When the wire is grounded you get no spark.
    There are two different types of "OFF" switches
    One is on the plate you just replaced so throttling down kills the engine
    The other is on the key switch and grounds the wire there
    To simplify ( and shorten ) the wiring a lot of mowers run the key switch kill wire to the throttle control kill wire
    So the kill wire from the magneto will go on the terminal on the insulated post .
  10. #10
    Join Date
    Aug 2019
    Posts
    Location
    New Jersey
    Mower
    Thanks...I should have taken a photo before I dissassembled it! I am a dummy!
Similar Threads
  1. My new (to me ) RER snapper
    By bobthewoodbutcher in forum Snapper Forum
    Last Post: 05-15-2017, 12:43 PM
  2. Old Snapper RER
    By Vervepipes in forum Snapper Forum
    Last Post: 05-29-2015, 08:54 AM
  3. Unmount wire bead tire from Snapper
    By cuengineer in forum Snapper Forum
    Last Post: 05-18-2015, 08:54 AM
  4. Snapper RER
    By larryenv in forum Snapper Forum
    Last Post: 09-05-2014, 12:02 PM
  5. New (to me) Snapper RER
    By snscosby in forum Snapper Forum
    Last Post: 06-30-2014, 05:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
