Grasshopper 721 - No power to coil
jhopkinson
I have an Grasshopper 721 gas with the Kubota engine and it's giving me fits. I'm not getting power to the coil, it starts if I run a jumper wire form the battery to the coil but otherwise I have no power to coil. I've checked/changed fuses and tried bypassing the seat switch. Not sure where to go for here...ignition? Relay? Any advice would be greatly appreciated.
John
jhopkinson
FIXED.....Re: Grasshopper 721 - No power to coil
Just posting a follow up in case someone has the same problem. It ended up being one of the relays under the instrument panel.
