I swapped the 6HP tecumseh for a 16HP Vanguard in my Wolf Cart.
But i have very small room for a battery.
About 15cm length, 8cm wide and 7cm tall.
Biggest battery i could find online that would fit inside the frame is a 3.2A lead-acid battery.
Is that sufficient to crank this ? Im using 100A ignition key and 100A Solenoid.
No other accessories.
Also need to figure out where to hook up the throttle cable, i can move the throttle plate moving the governer arm but not with the round plate thats also connected to it with a spring.
