echelonphoto
- Aug 19, 2019
- Threads
- 5
- 18
I have a 1995 series snapper 33 inch rider. I am in the process of replacing the axle boots. I am having a proble with the left side axle bearing. There is some kind of lock ring holding the axle in. It interfaces with the bearing on that side. There is a set screw in the ring which I did mangage to loosen pretthy easily, but the ring will not slide off. I tried pb blaster and heat and even tried a little puller to no avail. I could cut it off, but cannot find a similar part anywhere.
