Walk behind transmission assembly
Tog1007
Hi. New to the group. I am ineed of a parts diagram to help me reassemble the transmission on a Honda Harmony 215 SXA, Ser # MZBB-6162915. It is a 2 speed transmission.
Hellllp!
dougand3
All I see searching is the whole transaxle assy. As in, they don't part the internals. Bet you'll have to access a shop service manual - if it has an exploded IPL.
W did not get Harmony down here but in any case it is just a name and not used when searching for parts lists.
go here https://peparts.honda.com/powerequipment#/browse and work your way through the lists.
You will need the NUMBERS off the id tag and in particular the letters preceeding the numbers.
Tog1007
thanks for your reply. I need the inside of the transmission setup.
primerbulb120
Moderator
Are there any numbers on the transmission itself?
I did a parts lookup with model and serial numbers, and there are no diagrams available for the inside of the transmission. The parts diagram does note that it's a Tuff Torq transmission and not made by Honda. It's possible you may be able to find a Tuff Torq model number on the transmission case and use that to look it up...
