New member here, NJ
looking forward to all the insight everyone has for this crazy passion of ours... I have a 2008 Toro WB that I bought used / neglected and in need of repair. AS of right now the safety interlocks do not work at all. I've tested all the switches and they operate as expected when disconnected, I've ohmed out all the wiring to the switches and they appear ok. My only other item I believe is the control module. Any thoughts on how to test that? Before I buy at @ $85.. I've already sunken quite a bit of cash into it already.
current symptoms: without hands pressing down on the OPC's
Can engage PTO - still runs
Can put it in gear and it goes on it's own
machine turns off with key ( I replaced that switch)
greatly appreciate your feedback.
