757 z trak hydraulic system purge procedure
Does anybody have the hydraulic purge procedure for the Z trac 757. I have had to drain and flush the entire system due to a damaged pump replacement. this is the model with the single dual kanzaki pump. So I am starting with a new hydraulic filter, empty hydraulic tank. New pump, drained and flushed hydraulic lines and drained and flushed wheel motors.
D
Deleted member 97405
Guest
Here are the instructions straight from the tech book. The Kanzaki instructions begin about 2/3 down the left side of the page.
Thanks Will, that is what I was looking for.
no such thing as a flush to clean out lines or wheel motor or pumps. if it had oil in it and it had a hardware failure it sent metal fragments throughout the whole system. you must 100% disassemble and clean anything that had oil in it!!
