Results 1 to 6 of 6
  1. #1
    Join Date
    Sep 2019
    Posts
    4
    Location
    Georgia
    Mower
    B&S 11.5 Intek Won't Start
    I have an 11-year old Snapper riding mower with an 11.5 HP B&S Intek engine (NOT electric start) that (all of a sudden) won't start:
    1. In the past, engine typically starts on the very first pull and runs great
    2. Cut the grass a week ago just fine and shut off normally by cutting the gas flow to the carb
    3. Went to cut the grass a couple of days ago and NOTHING....would not start
    4. A couple of times (out of many) when I pulled the cord, it froze and would not pull....thought it was going to break my wrist!
    Here's what I've tried so far (not necessarily in order):
    a. Drained the tank and put in fresh gas...also replaced the fuel filter
    b. Pulled the carburetor off and cleaned out thoroughly (I put a new one on 6 months ago)
    c. Replaced the spark plug
    d. Replaced the magneto armature
    e. Pulled the flywheel and checked the flywheel key.... looked OK, but replaced just in case
    f. Removed valve cover and reset the valve clearance
    f. Sprayed starter fluid into the air intake... would not even think about firing
    Any other options that I might try? I'm out of ideas
    Attached Images Attached Images
  2. #2
    dougand3's Avatar
    Join Date
    Mar 2012
    Posts
    50
    Location
    Alabama
    Mower
    Re: B&S 11.5 Intek Won't Start
    Is plug wet or dry after no start? Could be flooding, so starting fluid makes it worse. I'd try starting fluid when you know plug and combustion chamber are dry. Check for spark. An inline tester is better as you see spark under compression. Compression is the other thing after all you've done.
    89 Craftsman GT18 44", 4 push mowers, Lotsa chainsaws.
  3. #3
    Join Date
    Sep 2019
    Posts
    4
    Location
    Georgia
    Mower
    Checked the plug after trying to start and it's dry and the spark looks good. In my original post I talked about how when I'm pulling to try and start.... every so often it will just lock up and not pull at all. Then the next pull is normal. What does this indicate?
  4. #4
    Join Date
    Mar 2015
    Posts
    709
    Location
    Illinois
    Mower
    Dixon
    I would disconnect the "Kill" wire from the engine and try. The interlock mod. often failed on these after several years. As for pulling/not pulling, sounds like the recoil is fouling up sometimes, perhaps recoil spring not tight enough OR could be the Compression Release is hanging up, bad spring.
    Walt Conner
  5. #5
    Join Date
    Sep 2019
    Posts
    4
    Location
    Georgia
    Mower
    With getting a good spark in the plug, I am assuming that the kill switch is not a problem. I also re-adjusted the valves again and checked to make sure that the push rods were not bent or damaged....all looking good. Nothing more than I know to do here. All suggestions welcome!
  6. #6
    dougand3's Avatar
    Join Date
    Mar 2012
    Posts
    50
    Location
    Alabama
    Mower
    Back to the basics:
    1. Proper fuel/air mix in the combustion chamber.
    2. Adequate compression.
    3. Good spark at the proper time.
    If above 3 happen - it has to run.
    So, is compression good enough? Sometimes, a tester is of limited use if engine has valve tick decompression. You might not pull rope fast enough to get past it.
Similar Threads
  1. B&S Intek 206, 5.5 hp won't start
    By flyfisher6032 in forum Small Engine & Mower Repair
    Last Post: 05-18-2019, 11:51 AM
  2. 206 Intek B&S 5.5, won't start
    By Nomatch1 in forum Briggs & Stratton Forum
    Last Post: 05-02-2019, 08:55 PM
  3. Briggs & Stratton Intek 190 won't start
    By Cougar281 in forum Small Engine & Mower Repair
    Last Post: 06-26-2018, 07:19 PM
  4. Replies: 7
    Last Post: 03-27-2017, 06:18 PM
  5. Ariens with B&S Intek 20HP V twin won't start normally
    By JoeLawnGuy in forum Briggs & Stratton Forum
    Last Post: 06-18-2015, 03:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
