Troybilt TB22 String Trimmer and the Flying Bump Knobs
unit91
  • / Troybilt TB22 String Trimmer and the Flying Bump Knobs
Outer housing looks like it is in good shape. String spool looks like it is getting chewed up,
unit91
Ordered a new spool. We'll see what happens. Thanks.
unit91
Installed new string spool with string, and new bump knob. Bump knob flew off after about 10 seconds, just like before. Is the bolt in the bump knob supposed to turn freely inside the knob or remain fixed?
It should be a square headed bolt inside the bump knob, and if it turned you couldn't screw it on.
unit91
It's as you described it. Bolt doesn't turn. Any chance it could be the string?
I don't think it is the string. The only other thing I could think is could be is the threads in the shaft where the bump knob screws into is worn, and loosing friction preventing the knob from properly tightening down. Something else to look at is make sure the internal thread cavity is clean. Maybe grass built up or something else causing a bottoming out effect.
unit91
Thanks, I'll check.
Jake8131
Sounds like the threads on the shaft that the bump knob screws into are stripped.
unit91
If I take the string spool off and run it with just the bump knob installed, the knob stays on at all speeds.
