For a 48" mower deck off of a S-16.
mcostello Active Member Joined Jun 10, 2012 Threads 9 Messages 68 Jul 17, 2019 / Ariens mower gear box needed. #1 For a 48" mower deck off of a S-16.
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 55 Messages 14,766 Jul 18, 2019 / Ariens mower gear box needed. #2 Could you provide us with the model and serial numbers for both the unit and deck. It sure would help your cause.
mcostello Active Member Joined Jun 10, 2012 Threads 9 Messages 68 Jul 19, 2019 / Ariens mower gear box needed. #3 The mower is an S-16, I did not notice a tag on the deck, will have to look later.
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 55 Messages 14,766 Jul 19, 2019 / Ariens mower gear box needed. #4 You will need more than that. Take a better look at your unit and you should find a black and silver tag with the model and serial numbers on it. Saying you have a S-16 is like me say I have an Ford F-150.
mcostello Active Member Joined Jun 10, 2012 Threads 9 Messages 68 Jul 21, 2019 / Ariens mower gear box needed. #5 Found a complete deck with gearbox, will have to see if it works.
