Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    Join Date
    May 2010
    Posts
    5,911
    Location
    Illinois
    Mower
    kioti/rhino finish mower
    Re: PTO strains as it spins up blades. Then weakly declines as soon as it starts cutt
    Spark plug, coil, valve clearances, and even head gasket can all be possible causes.
    ILLINOIS ENGINE, BEECHER CITY, IL
    BRIGGS AND STRATTON MST (MASTER SERVICE TECHNICIAN)
    Sales and Service for Dolmar/Makita, Poulan, Briggs and Stratton, Kohler, Lauson(Tecumseh, LCT), Brute, Honda, Subaru
    Warranty service for Snapper sold at Walmart, Craftsman by MTD, Murray, Karcher, Earthquake, Yamaha engines, American Landmaster, Worx, Rockwell Tools, Great Lakes Technologies products(Wen, CZ), Generac portable/DR power and others.
  2. #12
    Join Date
    Jul 2019
    Posts
    4
    Location
    Texas
    Mower
    2004 Hustler Fastrak 52
    Quote Originally Posted by bertsmobile1 View Post
    Here is he rub that most people seem to miss.
    You test things to verify if they are working or not rather than making blind stabs in the dark.
    There is an engine in the workshop with a complete piston & rod missing.
    The customer had the mower for 5 years and thought it was a bit gutless.
    It had been serviced 3 time by the vendor.
    He was ill & his wife could not start it so she called my predecsor.
    There was not a mark on the crankshaft, the engine left the factory with only one piston.
    Briggs did the right thing & sent a replacement engine.
    So the first thing to do is pull one plug out, ground the plug and try to start the engine.
    Do it for both sides
    Each side should start & run the same if both cylinders are working.
    IF one side is not working then we do some more digging around to find out why it is not working.
    Thank you. That's one heck of a situation there and it makes a good point.
    I checked the cylinders by removing the plug caps one and then the other. They both fired up equally.
    I think / guess I should drop the belt and check each spindle bearing for play or misalignment next. I'm open to any other suggestions too of course.
    If those are fine and I get to the clutch, are there any hand turning type of checks or such that can be done there?
Similar Threads
  1. Replies: 17
    Last Post: 07-13-2019, 07:32 AM
  2. GX345 blades keep cutting off
    By JDpaininbutt in forum Small Engine & Mower Repair
    Last Post: 09-06-2018, 11:02 PM
  3. Replies: 6
    Last Post: 09-28-2017, 09:18 PM
  4. Need new cutting blades STX38
    By silver1 in forum John Deere Forum
    Last Post: 09-04-2015, 12:07 PM
  5. Toro Z420 blades cutting at different heights
    By toroz420 in forum Toro/Wheelhorse Forum
    Last Post: 05-18-2013, 09:18 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
