Results 1 to 3 of 3
  1. #1
    Join Date
    Jun 2019
    Posts
    Location
    Maryland
    Mower
    Auto safety blade shut off
    First time posted here. I am hoping I can find advice on how to defeat the safety feature that turns off the blades when going in reverse. I have a2012 JD X300.
  2. #2
    LawnWorld Support Catherine's Avatar
    Join Date
    Jun 2015
    Posts
    1,386
    Location
    California
    Mower
    Kubota
    Re: Auto safety blade shut off
    Welcome to the forum!
    I'm going to move this thread over to our John Deere section.
    Catherine
    LawnWorld Support
  3. #3
    Join Date
    Nov 2014
    Posts
    11,436
    Location
    Australia
    Mower
    Victa slashers & Push , Rover Rancher II's, Cox ( several ) & White LT120 + GT 200
    I never tell anyone or even advise anyone to defeat a safety switch no matter how stupid & useless it is like the MIR system.
    I will tell you how it works. what you choose to do then is your business.
    Somewhere there is a plunger switch which when activated will either make a circuit or break a circuit.
    It has to be placed somewhere easy to access where a control arm can hit and depress plunger.
    So the best place is on the tranny.
    Usually it will be a normally open switch so an arm depressing the plunger closes the switch and creates a ground path for the magneto coil which kills the engine.
    Better ones use a relay to power the blade clutch & the switch trips the relay to turn off the blades.
    They are always ground circuits
Similar Threads
  1. Replies: 0
    Last Post: 07-10-2017, 02:47 PM
  2. Replies: 6
    Last Post: 05-29-2017, 10:13 PM
  3. The blade won't shut off when the mower is in idle!
    By roolou in forum Small Engine & Mower Repair
    Last Post: 06-17-2015, 06:35 PM
  4. SAFETY SHUT-OFF
    By DAVE D in forum Small Engine & Mower Repair
    Last Post: 05-06-2013, 07:25 AM
  5. john deere x320. reverse shut off safety
    By mowerman05 in forum Commercial & Residential Lawn Mowing
    Last Post: 03-22-2013, 08:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
