Results 1 to 9 of 9
  1. #1
    Join Date
    Jun 2019
    Posts
    5
    Location
    Louisiana
    Mower
    725D Bogging and killing
    my 2016 725D just started to bog down when you push the sticks forwards, seems to do it after its been running a while. it used to clear up but is now starting to die when it bogs does this in cut grass. just wondering if anyone has had this type of issue.
  2. #2
    1,000 Post Club
    Join Date
    Aug 2015
    Posts
    1,664
    Location
    Kansas
    Mower
    Toro/Cub Cadet/Kubota
    Re: 725D Bogging and killing
    Diesel? Probably needs a new fuel filter.
  3. #3
    Join Date
    Jun 2019
    Posts
    5
    Location
    Louisiana
    Mower
    Itís a diesel, thatís where I was planning to start
  4. #4
    BWH's Avatar
    Join Date
    Mar 2011
    Posts
    316
    Location
    Nebraska
    Mower
    725DT6 Grasshopper, 1455 Bolens,1250 Bolens, LT180 J.D.
    Dusty did the new fuel filter clear thins up on your 725?
    Just curious.
  5. #5
    Join Date
    Jun 2019
    Posts
    5
    Location
    Louisiana
    Mower
    Not quite sure just yet, I started with replacing the air filters, motor was running good then it started acting up and killed, tried to start it and wouldnít stay running. I then replaced the fuel filter and bled the air out, it started up and ran but was acting kinda funny, Iím thinking there may be some air trapped somewhere and itís working it out. I have about seven acres to cut so Iíll try it out again this week and see what happens
  6. #6
    BWH's Avatar
    Join Date
    Mar 2011
    Posts
    316
    Location
    Nebraska
    Mower
    I think I know exactly what you mean when you say its acting funny, I recently ran my 725 D out of fuel. I added fuel and pumped the primer lever and it started but it wasn't quite right. I shut it down and pumped the diesel primer lever a few more times and restarted, it still wasn't quite right but 45 seconds later it was back to normal.
    Good Luck
  7. #7
    Join Date
    Jun 2019
    Posts
    5
    Location
    Louisiana
    Mower
    It seems to be doing a lot better, cut the grass this past weekend without any issues. So Iím hoping it was just the fuel filter
  8. #8
    Join Date
    Jun 2019
    Posts
    5
    Location
    Louisiana
    Mower
    Well just when I thought it was doing better it started acting up again it looks like it stops pumping fuel from the tank, I pulled the fuel pickup line from the tank and there is no suction than I can feel, I let the mower sit for a few hours and it started back up and run. Iím guessing it has a mechanical fuel pump so I will have to look Into that
  9. #9
    Join Date
    Jul 2019
    Posts
    Location
    Akron
    Mower
    dustyj, thx for topic! I feel your pain.
    hello to all, just joined after acquiring first grasshopper approx a 2001 721D.
    Won't rant about PO lying about "needs nothing" but really getting to know my machine this way I guess.
    Anyway have had similar prob with slowing down and dying. Mechanical fuel pump. bleed lines, starts runs strong maybe 10 min till no more fuel seen in first filter then dies.
    Havent replaced filters yet but if manually fill the filter it started ran and sucked more fuel out of a jar of fuel so cant see filter as prob and seemed pump working, at least intermittently.
    Pickup in tank clear.
    To me it would seem an intermittent failing of pump if that is possible.
    Anyone tried subbing in an electric fuel pump which would be way cheaper than new mech?
Similar Threads
  1. Grasshopper 725D Need Help
    By CvilleBanjo50 in forum Small Engine & Mower Repair
    Last Post: 03-26-2019, 02:43 PM
  2. 725D PTO Belt Replacement
    By bmoney7 in forum Grasshopper Forum
    Last Post: 06-25-2017, 01:43 PM
  3. Belt on 725d Grasshpooer
    By cambre in forum Grasshopper Forum
    Last Post: 10-05-2014, 08:10 AM
  4. No electrical power to console. 725D
    By Ammo Dave in forum Grasshopper Forum
    Last Post: 05-05-2014, 03:50 PM
  5. Grasshopper 725D T6
    By loganmower in forum Mower & Equipment Buying & Pricing
    Last Post: 03-09-2014, 12:57 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
