I have a Toro SS5000. I think from 2011 (I'm at work and don't have the exact model or serial number). I was cutting the grass and going in reverse, went to start driving forward and the mower would not move. The engine was still running. I turned the engine off and checked the electric brake, it was engaged. I reset it, and sit down and try to start the mower. As soon as I turn the key you hear the electric brake engage, the mower will start up but the brake never disengages and will not go forward or reverse. I had a similar problem a couple weeks ago and I replaced the electric brake and solenoid. In that case it was a bad solenoid. (surely the new solenoid is not bad already). Any help is appreciated.
