Yea weird someone complaining about a too tight turning radius right? Well my 2014 Regent 48” fabricated deck mower actually does. I always noticed it seemed to steer too far in each direction. Not a problem if you go very slow in the turn but if your going down a hill and turn a tad too sharp it can begin to pull itself around further until you are actually pushing the wheel sideways. It happened once and bent the long steering cross arm which I replaced with nothing else showing damage. The sector and shaft gear are fine as far as I can see but it still has that oversteer tendency. I was wondering if anyone else ever noticed this. I’m not a machine pounder by the any means but this thing seems to always want to pretend it’s a zero turn. Any ideas?
