Results 1 to 5 of 5
  1. #1
    Join Date
    Aug 2017
    Posts
    5
    Location
    Texas
    Mower
    Kubota
    Question PTO Sometimes Does Not Engage
    I have a Kubota Kommander Z121S. Recently it has failed to engage the pto motor when I pull the pto button up. Sometimes if I leave the button up it start after several seconds. Most of the time I cut it on and off until the blade motor kicks in. Could I be lucky enough for this to just be the switch giving up the ghost? 😳
  2. #2
    1,000 Post Club
    7394's Avatar
    Join Date
    Sep 2014
    Posts
    1,931
    Location
    Tennessee
    Mower
    Toro Z w/Kaw
    Re: PTO Sometimes Does Not Engage
    I would check the ground for good solid clean connection
    Buddy.......... My Kawasaki FR to FX Air Box mod https://www.lawnmowerforum.com/showt...box-conversion
  3. #3
    2,500 Post Club
    Join Date
    Jul 2013
    Posts
    4,892
    Location
    Georgia
    Mower
    2010 simplicity broadmoor 46" deck 20hp vanguard
    possibly, i would also check air gap at PTO clutch itself 3 places.
    https://www.google.com/search?q=how+...hrome&ie=UTF-8
    https://www.google.com/search?ei=0k2...60.Z3f-72Om0Tw
  4. #4
    Join Date
    Aug 2017
    Posts
    5
    Location
    Texas
    Mower
    Kubota
    Quote Originally Posted by 7394 View Post
    Thank you sir! I will check it out!
  5. #5
    Join Date
    Aug 2017
    Posts
    5
    Location
    Texas
    Mower
    Kubota
    Thanks for the help! Replaced the pto switch with a ten amp upgrade and it is now working fine!
Similar Threads
  1. Mower deck D105 PTO won't engage - replaced belt & PTO engagement cable
    By desijogi in forum John Deere Forum
    Last Post: 07-10-2018, 10:06 PM
  2. PTO will not engage
    By lislewh in forum Small Engine & Mower Repair
    Last Post: 05-20-2017, 10:09 PM
  3. new pto switch and new pto clutch want engage
    By butter_milk in forum Small Engine & Mower Repair
    Last Post: 06-25-2016, 11:41 AM
  4. How to engage the PTO?
    By Dowd_Elwood_P in forum Mower & Equipment Operation
    Last Post: 03-19-2015, 11:22 PM
  5. pto wont engage pto motor
    By luremaker in forum Small Engine & Mower Repair
    Last Post: 09-18-2013, 08:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
