Hi I have an old Exmark Lazer Z with a command pro CH745 engine and Bosch EFI system.
Last year I replaced the head gaskets. It ran fine till the end of the mowing season.
At that time it would shut off after mowing for about an hour and a half. Would crank and not start. Fuel pump would click on and off. Then after cooling off it would start again.
I replaced the fuel pump but it was still doing the same thing.
I just started it up and used it for the first time this year. Same issue ran for an hour and half then shut off and would not start. After it cooled off it would run but not well, surging, missing, seemed like a fuel problem. The relay for fuel pump(I think) kept clicking.
This time it has a code 23 - defective ECU.
Anyone have experience with this. Do ECU's go bad and cause issue like this? Before spending the $$$ for an ECU could there be another cause?
Thanks
Thanks
