I have the 2017 or 18(probably 18) raptor SD 54"
I know this has been discussed after digging around some but what is the official accepted fix for the grass buildup under the raptor's deck? Mine gets so much grass stuck to the bottom that once I park it in the shop after a week the shop STINKS with an ammonia smell because the grass stuck on the bottom of the mower is molding. I have tried cutting with the chute up...seems to help some...I changed the blades this season to the oregon hustler stock equivalents. I'm not sure what else there is ... i see some folks cutting the opening a tad bigger? what other tips tricks?
