Results 1 to 3 of 3
  1. #1
    Join Date
    May 2014
    Posts
    4
    Location
    Alabama
    Mower
    Blades will not engage........
    I have a ZTM 61"..it starts, runs good..however the blades will not engage when I pull the PTO nob...no noise, no sounds what so ever..what to check for???
    Any help will be appreciated. I put a new PTO switch, silenoid and charged the battery yesterday after it sat up during the winter months. I only found two fuses, they both looked good...I'm stuck!!!! Thanks....
  2. #2
    2,500 Post Club
    Join Date
    Jul 2013
    Posts
    4,899
    Location
    Georgia
    Mower
    2010 simplicity broadmoor 46" deck 20hp vanguard
    Re: Blades will not engage........
    check all electrical connections by hand making sure they are tight & secure, check air gap at pto clutch three places
    https://www.google.com/search?q=how+...hrome&ie=UTF-8
  3. #3
    Join Date
    Nov 2014
    Posts
    11,817
    Location
    Australia
    Mower
    Victa slashers & Push , Rover Rancher II's, Cox ( several ) & White LT120 + GT 200
    Funny you should post this today.
    One of yesterdays call outs was for exactly the same thing.
    Investigations showed the clutch wires had been fouling on the drive pulley above it.
    The wires had been worn bare.
    The mower goes back to the dealer for a warranty repair.
    It looks like AYP has fitted a different clutch from the original design because there is no way the wires can be routed without fouling on the pulley.
    It needs a clutch where the wires come out of the base sideways because there is only about an inch between the clutch & the top pulley.
Similar Threads
  1. Replies: 1
    Last Post: 05-14-2016, 05:06 AM
  2. Blades do not engage
    By Mayway in forum Small Engine & Mower Repair
    Last Post: 12-13-2014, 09:01 PM
  3. Replies: 1
    Last Post: 04-27-2013, 01:29 PM
  4. Can't engage blades
    By jcoukos in forum Scag Forum
    Last Post: 10-14-2012, 10:35 AM
  5. Repairs blades will not engage
    By Colonel in forum Scag Forum
    Last Post: 09-16-2011, 01:12 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
