Results 1 to 4 of 4
  1. #1
    Join Date
    Feb 2019
    Posts
    Location
    Georgia
    Mower
    Husqvarna
    husky tractor mower sputters when blades are engaged
    I have a Husqvarna tractor mower that backfires and the engine runs real rough when I engage the blades. If I turn the key to the position to backup with the blades engaged then it smooths right out and runs fine. If I push the clutch in it smooths out and runs fine. Any help would be greatly appreciated.
  2. #2
    2,500 Post Club
    Join Date
    Jul 2013
    Posts
    4,899
    Location
    Georgia
    Mower
    2010 simplicity broadmoor 46" deck 20hp vanguard
    Re: husky tractor mower sputters when blades are engaged
    sounds like you need a tune-up, adjust valves, oil & filter change, spark plug replacement, air filter, inspect belts for replacement, idler pulleys, grease spindles & all grease fittings, steering sector & pinion gears need grease.
  3. #3
    1,000 Post Club
    Boudreaux In Eunice La.'s Avatar
    Join Date
    Jul 2017
    Posts
    2,146
    Location
    Louisiana
    Mower
    A bunch of dem things.....
    Quote Originally Posted by PTC Small Engine View Post
    Is it a Twin cylinder ?????
    Briggs and Stratton Dealer, Warranty center for Tractor Supply Co.
  4. #4
    Join Date
    Feb 2019
    Posts
    8
    Location
    Michigan
    Mower
    racing mower
    The reverse safety circuit that kills the engine if you go in reverse with the blades on is likely acting up. I especially think this is true because you said the engine smooths out when you push that button/switch.
Similar Threads
  1. Husky YTH24V48 Sputters and Stalls When Brake Released
    By timb69 in forum Husqvarna & Dixon Forum
    Last Post: 12-01-2018, 01:31 AM
  2. Replies: 6
    Last Post: 07-30-2016, 11:01 AM
  3. Replies: 0
    Last Post: 04-25-2014, 09:30 PM
  4. Engine John Deere 145 lawn tractor stalling when blades engaged
    By BrianW in forum John Deere Forum
    Last Post: 05-19-2012, 07:35 AM
  5. John Deere 145 Lawn tractor stalling when blades engaged
    By BrianW in forum Small Engine & Mower Repair
    Last Post: 05-18-2012, 10:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
