Results 1 to 2 of 2
  1. #1
    Join Date
    Jan 2019
    Posts
    Location
    Texas
    Mower
    Troy-Bilt
    Stuck shift lever on a new Troybilt Big red.
    The shift lever was getting progressively harder to shift. Now it will not shift at all nor can it be shifted to reverse. I checked the drive belt. It's loose. The handle is frozen. New tiller, starts OK, can be pushed OK. The hi and lo speed lever also works.
  2.
  3. #2
    Join Date
    Nov 2014
    Posts
    10,300
    Location
    Australia
    Mower
    Victa slashers & Push , Rover Rancher II's, Cox ( several ) & White LT120 + GT 200
    Re: Stuck shift lever on a new Troybilt Big red.
    Have a real good look at the shafts.
    The bushes wear then make the gears hard to shift.
Similar Threads
  1. Shift lever question
    By MowLife in forum Transmissions & Transaxles
    Last Post: 12-14-2018, 11:39 AM
  2. Replies: 2
    Last Post: 07-08-2013, 02:26 PM
  3. Why does a Troybilt Big Red Horse mow so slow?
    By rayman in forum Troy-Bilt Forum
    Last Post: 09-25-2012, 03:53 PM
  4. Troybilt big red 4-cycle trimmer problem
    By Slowride in forum Small Engine & Mower Repair
    Last Post: 04-20-2012, 06:40 PM
  5. Belt Change/ Big Red Horse
    By southernkilowatt in forum Small Engine & Mower Repair
    Last Post: 09-14-2011, 10:40 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
