Yard bug
Phrank671
Just got a yard bug 9.5 hp engine runs great .when i try to engage blades the engine cuts off the same for the gas pedal it also cuts engine .
The cables forward /reverse with not move at all .Tried spraying cables but no luck .Any ideas?
Model of yard bug is 13A-325-402 Also notice that the blade will engage and belts will turn by manually holding them using a screw driver to bring in pulley system .
