Husqvarna YTH24V48 Bagger Compatibility
RZ3016
I recently picked up a Husqvarna 48" and am looking for a bagger for it. Does anyone know if the Craftsman 917.248921 bagger for a 42" will work at all or what will need to be done to adapt it? I found someone locally with one for sale, but am vaguely told by Husq/Crafts it is for a 42" deck which is known and they cannot tell if it will actually go on a 48" being brackets, etc may differ slightly causing issues. I am just looking around on Craigslist to see what will work for it.
BlazNT
From what I know about it it doesn't attach to the frame correctly. The 42 and 48 have different holes for frame mounting.
RZ3016
Thanks for the reply. The rear mount bracket position for a 42” looks identical to the 48” position along with mounting holes.... ?
