Walk behind Walk Behind Wiring Help Needed
NCDiscgolfer
Well, my wife insisted on getting goats and they have eaten through my wiring harness. I guess that was to be expected when adopting furry "kids."
The Problems:
No way to identify the exact model (Hydro late 90s early 2000s i believe)
Unable to find an exact wiring harness without the model (Over $200 even if i could)
there are 8 wires coming from handles and 7 leading to the deck
I am not an electrician (but i do learn quick)
The Kohler Command 17.5 is not the original engine
If possible, I would like to directly connect the wires without the use of a harness. I would say the majority of the wires are easily paired by color. However, the extra wires are throwing me off. Any help would be appreciated.
BlazNT
All of your wires are a single plug-in type. One wire for one plug. What you will have when done is an unused wire. Black tape it.
NCDiscgolfer
Ok great. I assume it's one of the red wires I'll just need to figure out which one. Thank you
