- Nov 29, 2014
- Threads
- 64
- 24,647
Walt is quite right , I should not need to "me too" his posts.
Cool bore engine can not be bored out oversize successfully.
Briggs use the same size piston is engine that are all iron, alloy with iron or steel liners, alloy with chrome plated bore and all aluminium
Thus +20's and even + 40's are available.
Boring is done in thous from .5 up to around 15.
Honing is done in hundredths of thous to clean up the ridges left by the boring bar or clean the glaze off worn cylinder walls, replace the cross hatching or to size very accurately.
Honing .010" off a bore wall by honing would be near a whole day of machining and wear out a complete set of stones.
