Results 1 to 6 of 6
  1. #1
    Join Date
    Oct 2018
    Posts
    Location
    United States
    Mower
    LawnBoy
    Question Problems With 80's Lawn Boy Model: S19ZPN
    Hello Lawn World
    A few months ago my 80's era (unsure of the precise year) lawn Boy model S19ZPN cut out on me mid-mow. Today I finally got around to diagnosing and eventually starting the mower after concluding that I hadn't added 2 cycle oil to my fuel. Luckily for me, that didn't destroy my engine and it started right up. In addition to the repair, I added epoxy clay to the wire the controls the choke valve in the carburetor (excuse my uncertain language). It ran and I let it warm up and then I left it for 15 minutes while I ran to the store to grab carburetor cleaner to mix with the gas since the mower had sat for a while. However, when I got back and added the mixture it would not start. I double checked everything including my epoxy job and it will not start back up.
    Now I am asking for the help of the internet. I can conclude (correct me if I'm wrong) that there is spark otherwise it wouldn't have started in the first place and the engine is (or did) get gas. What am I missing? If I were to guess, something is wrong with the safety toggle. Thanks in advance!
    Willam
  2. #2
    Join Date
    Mar 2016
    Posts
    91
    Location
    Florida
    Mower
    lawnboy,honda,stihl
    Re: Problems With 80's Lawn Boy Model: S19ZPN
    I would start by checking compression.Dan
  3. #3
    Russ2251's Avatar
    Join Date
    Mar 2018
    Posts
    208
    Location
    Huntington Station, Long Island, New York
    Mower
    Lawn-Boy(6) Craftsman, Craftsman LT2000, Rally...and NO SEAFOAM or any other additives.
    I can conclude (correct me if I'm wrong) that there is spark otherwise it wouldn't have started in the first place...
    Perhaps the coil has failed. Check for spark.
  4. #4
    Join Date
    Mar 2016
    Posts
    91
    Location
    Florida
    Mower
    lawnboy,honda,stihl
    Reading what have happened,I see two problems:
    1 run mower with out 2-cycle oi
    2 adding carb cleaner to gas ???
    Now if do not have good comp,tester,-do the fallowing: remove blade & blade adapter next remove muffler.You should be able to see piston & rings,if they score --rebuilt the engine.Dan
  5. #5
    Join Date
    Oct 2018
    Posts
    Location
    United States
    Mower
    LawnBoy
    Quote Originally Posted by bogdaN View Post
    The carb cleaner was a fuel additive. Fuel injector and carberator cleaner. Also the engine ran once for a good amount of time before crapping out again which proves the engine didnít seize right?
  6. #6
    Russ2251's Avatar
    Join Date
    Mar 2018
    Posts
    208
    Location
    Mower
    An engine that rotates is NOT SEIZED!!!
    Check for spark.
    Model F coils are prone to failure.
Similar Threads
  1. Lawn Boy self propelled problems.
    By rlaman in forum Small Engine & Mower Repair
    Last Post: 05-24-2016, 05:25 PM
  2. Problems identifying my lawn boy
    By David2022 in forum Lawn Boy Forum
    Last Post: 10-10-2014, 09:19 PM
  3. Lawn-Boy Golden Boy Anniversary Model Mower???
    By Guidotkp in forum Lawn Boy Forum
    Last Post: 09-25-2014, 11:56 AM
  4. Lawn-Boy S19ZPN Excellent Condition on eBay
    By Pcfithian in forum Private Party Ads
    Last Post: 07-25-2014, 10:28 AM
  5. Engine Lawn Boy Model 10525 Engine Problems
    By Kelch in forum Lawn Boy Forum
    Last Post: 12-13-2012, 01:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
