- Nov 29, 2014
- Threads
- 64
- 24,702
yes the blade is on upside down.
That will raise the cutting height a whopping 1.25" which on a mower with a max height of 4.5" is just under 30%.
When you adjust the deck height you do the rear then the front.
If you just raise the front you will end up cutting lower because the nose will dive down.
You could try moving the round rods with the R clips forward 1 hole.
This will both raise the deck and move it backwards.
Be careful doing this because the pulleys can end up fouling under the mower and the belt will be pulled tighter so the blades might not dissengage.
Even worse, they stop the just as you are going over something they start up again.
