Sorry, I am a noob here, I attempted to use the search function for similar threads, but didn't find one.
Anyways, I have a the HRR2165VXA, it runs and mows great, but recently it started to not turn off when I move the throttle lever to the off position. For a while I was able to manually push the throttle body lever forward to kill it (not sure the actual name, but the lever that the throttle cable attaches to), now that isn't doing the trick either. I have tried replacing the throttle cable, but that has not taken care of the problem either. The easiest way for me to turn the mower completely off is by putting it in the stop position, then engaging the blades.
Any ideas of what my problem would be?
Thanks in advance for the help!
