Results 1 to 3 of 3
  1. #1
    Join Date
    Sep 2018
    Posts
    Location
    Ohio
    Mower
    MTD1448 PRO
    17.5 HP briggs and stratton pull start with carb selanoid
    I replaced the engine on my MTD 1448 Pro mower with a pull start 17.5 B&S engine that came with equipped with a carb solenoid, info states alternator current is not regulated and will over charge a battery. does pull starting provide enough current if connected to the lighting output connector to open selanoid or must it be removed for manual start?
  2. #2
    Join Date
    Nov 2014
    Posts
    11,513
    Location
    Australia
    Mower
    Victa slashers & Push , Rover Rancher II's, Cox ( several ) & White LT120 + GT 200
    Re: 17.5 HP briggs and stratton pull start with carb selanoid
    No.
    Remove the solenoid and replace it with a bowl bolt.
    Chances are the one off the old carb will fit the new one because they never changed the thread size.
  3. #3
    Join Date
    Sep 2018
    Posts
    Location
    Ohio
    Mower
    MTD1448 PRO
    Quote Originally Posted by bertsmobile1 View Post
    No.
    I will modify solenoid pin to disable, original engine is different brand. Thanks
Similar Threads
  1. I pull the rope on my Briggs and Stratton 6.75 HP engine and it gets stuck
    By washburnsatch in forum Briggs & Stratton Forum
    Last Post: 05-23-2015, 04:58 PM
  2. Briggs & Stratton 675 Pull Cord
    By jhooker505 in forum Briggs & Stratton Forum
    Last Post: 04-13-2014, 09:33 AM
  3. Problem with Briggs and Stratton pull start assembly
    By Johnnywycliffe in forum Murray Forum
    Last Post: 06-30-2013, 03:39 PM
  4. Briggs and Stratton Carb Identification - Carb Kit Needed
    By thebrok2 in forum Briggs & Stratton Forum
    Last Post: 06-02-2013, 08:36 AM
  5. Briggs & Stratton Pull Chord
    By TruXter in forum Briggs & Stratton Forum
    Last Post: 01-25-2012, 08:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
