so 18 hp v twin it will idle but if you move the throttle it will miss...if you start it in full throttle it will run then move the throttle it will miss fire. if you unhook the gov and run it by hand it will run but when you move fast it will miss. do you think it is in timing or what stumped.:confused2:
