Results 1 to 5 of 5
Thread: valve lash
  1. #1
    Join Date
    Nov 2012
    Posts
    252
    Location
    New York
    Mower
    Ferris
    valve lash
    Working on a Briggs single cylinder 17.5 hp. I need to know what to set the valve lash at. thanks, gregjo1948
  2.
  3. #2
    Join Date
    May 2010
    Posts
    5,362
    Location
    Illinois
    Mower
    kioti/rhino finish mower
    Re: valve lash
    Assuming OHV engine and not flathead the setting would be .004-.006 for both valves.
    ILLINOIS ENGINE, BEECHER CITY, IL
    BRIGGS AND STRATTON MST (MASTER SERVICE TECHNICIAN)
    Sales and Service for Dolmar/Makita, Poulan, Briggs and Stratton, Kohler, Lauson(Tecumseh, LCT), Brute, Honda, Subaru
    Warranty service for MTD, Murray, Karcher, Earthquake, Yamaha engines, American Landmaster, Worx, Rockwell Tools, Great Lakes Technologies products(Wen, CZ), Efco, Generac portable/DR power and others.
  4. #3
    Join Date
    Nov 2012
    Posts
    252
    Location
    New York
    Mower
    Ferris
    Re: valve lash
    Thanks ilengine. It is an overhead valve engine. Did Briggs even make a 17.5 hp flathead? gregjo1948
  5. #4
    Join Date
    May 2010
    Posts
    5,362
    Location
    Illinois
    Mower
    Re: valve lash
    In theory I am sure they did. Could of just been a relabeled 16 or 17 hp engine. There was a lot of that several years ago. I saw a 40 series opposed twin briggs several years ago with a 12.5 sticker on the housing. that was normally a 16 if I remember correctly.
  6. #5
    Join Date
    Mar 2015
    Posts
    562
    Location
    Illinois
    Mower
    Dixon
    Re: valve lash
    Actually the 40 series opposed twin started out as a 12.5 hp. It grew to a 14 hp then finally a 16 hp. At the end of the run of 42 and 46 opposed twins several different stickers were stuck on the remaining engines, lower than their original rating and generally ending in .5. All the other remaining flat head stock was done similar.
    While Illinois is a pro and his settings will work, actual spec is .003"- .005" for the Intake and .005"- .007" for the exhaust. I go for the min. on the Intake for compression release reasons.
    I can send you detailed instructions on setting the valves AND a Service Manual IF you like. Address below, put in proper format and remind me engine model number and what you want.
    Walt Conner
    wconner5 at frontier dot com
Similar Threads
  1. valve lash check/adjustment
    By Boit4852 in forum Mower & Equipment Operation
    Last Post: 08-06-2018, 10:59 AM
  2. Valve lash
    By BHump in forum Small Engine & Mower Repair
    Last Post: 10-22-2016, 05:43 PM
  3. Valve lash
    By ghost1 in forum Dixie Chopper
    Last Post: 04-08-2016, 04:45 PM
  4. Setting Valve Lash
    By kcrego in forum Craftsman Forum
    Last Post: 11-11-2014, 12:20 AM
  5. Can i reduce valve clearance/lash by lapping?
    By tiresharkdbb in forum Briggs & Stratton Forum
    Last Post: 11-03-2014, 02:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
