Results 1 to 10 of 10
  1. #1
    Join Date
    Aug 2018
    Posts
    Location
    Maine
    Mower
    what oil for my 1966 110
    i recently bought a 1966 110 wondering if somebody knew what oil to use didnt know if this was back when we used non detergent oil thanks
  2.
  3. #2
    BlazNT's Avatar
    Join Date
    Apr 2012
    Posts
    6,332
    Location
    Missouri
    Mower
    RZ5424
    Re: what oil for my 1966 110
    How about the numbers off the engine?
    Chuck
    We Do Not Stop Playing When We Grow Old
    We Grow Old If We Stop Playing
  4. #3
    Join Date
    Aug 2018
    Posts
    Location
    United States
    Mower
    Quote Originally Posted by ricsess View Post
    Always use detergent oil in any internal combustion motor, only pumps can use non-detergent since there isn't any dirt produced by just the lubrication in a pump.
    The older oils may not have had as good a detergent in their mix but all engines need the cleaning agents or detergents in their oil.
  5. #4
    Join Date
    Nov 2014
    Posts
    10,101
    Location
    Australia
    Mower
    Victa slashers & Push , Rover Rancher II's, Cox ( several ) & White LT120 + GT 200
    IT makes absolutely no difference to the mower, the oil pump or any other mechanical device weather the oil is detergent or non-detergent.
    Forget all the rubbish you have seen on TV read in glossy magazines or heard on the radio.
    It is all pig droppings, not even bull written by very cleaver people who have never done a day of science or engineering in their life.
    The deciding factor on detergency is the type of filter.
    Detergents were added to oils to hold the impurities in solution as fine particles so that the paper oil filter can remove them easily without becoming clogged
    End of story
    Prior to the common use of disposable paper filters oil was either centrifugally filtered or the oil went into a deep tank to sludge out.
    It is always a source of mirth that people who know absolutely nothing about the chemistry of oils will argue about detergentcy with violent passion.
    What is important for mower oils are the anti corrosion additives, anti oxidation additives and water dispersal additives because the engine sits there for months not moving.
  6. #5
    Join Date
    Aug 2018
    Posts
    Location
    Maine
    Mower
    thanks for all comments
  7. #6
    Russ2251's Avatar
    Join Date
    Mar 2018
    Posts
    167
    Location
    Huntington Station, Long Island, New York
    Mower
    Lawn-Boy(6) Craftsman, Craftsman LT2000, Rally...and NO SEAFOAM or any other additives.
    Some folks THINK they know more than the engineers.
    It's a narcissistic thing.
  8. #7
    Join Date
    Nov 2014
    Posts
    10,101
    Location
    Australia
    Mower
    But I read it on Face book so it must be true cause he has 2,987,789 likes and 50,000 friends.
    The annoying bit is if you look up detergent oil in wikki, the correct answers are all there
    I only got 1 hour a week for 13 weeks to cover oils, lubricants , cutting fluids & coolants which was just enough to show we knew next to nothing about them
  9. #8
    1,000 Post Club
    Join Date
    Sep 2013
    Posts
    1,000
    Location
    Texas
    Mower
    Dixon ZTR, Kubota H1400, John Deere LX277, Yardman, Honda HR214, several Snappers with Honda engines
    Quote Originally Posted by BlazNT View Post
    tractordata.com says...The 8-horsepower Kohler K181 replaced the K161 for the 1964 model year. The K181 was available throughout the production run of the 110.
    Kohler K181S
    gasoline
    1-cylinder
    air-cooled
    305 cc [18.64ci ]
    Bore/Stroke: 2.9375x2.75 inches [75 x 70 mm]
    Power: 8 hp [6.0 kW]
    Air cleaner: dry
    Compression: 6.8:1
    Rated RPM: 3600
    Starter volts: 12
    Oil capacity: 0.625 qts [0.6 L]
  10. #9
    AnthemBassMan's Avatar
    Join Date
    Apr 2014
    Posts
    149
    Location
    T-County, Ohio!
    Mower
    LawnBoy
    Well hereís a screenshot from the actual Kohler owners manual. But personally, if the engine has not been rebuilt, Iíd run a good 15w40 oil.
    And hereís the link to read through the entire manual. Itís just for the Kohler engine, not the John Deere 110 manual.
    http://resources.kohler.com/power/ko..._593_f_all.pdf
    L8R,
    Matt
    1973 Lawn Boy 7262
    1975 Lawn Boy 5024 Bricktop
    Echo CS370 Chainsaw
    Poulan P1500 trimmer
  11. #10
    Join Date
    Nov 2014
    Posts
    10,101
    Location
    Australia
    Mower
    Any air cooled engine oil will be fine and any mower oil will be even better and better still if it gets drained at the end of every season so over winter when corrosion happens you have nice clean oil in there.
    Viscosity according to the local conditions.
Similar Threads
  1. troybilt 110
    By dewanda1 in forum Small Engine & Mower Repair
    Last Post: 06-16-2017, 05:11 PM
  2. 1966 Pennsylvania Meteor
    By big_j_43 in forum Mower & Equipment Buying & Pricing
    Last Post: 05-29-2015, 07:18 PM
  3. 1974 JD 110
    By dhall57 in forum Mower & Equipment Buying & Pricing
    Last Post: 04-19-2015, 07:58 PM
  4. John Deere L 110
    By Joebob in forum John Deere Forum
    Last Post: 05-19-2013, 10:44 PM
  5. New 110
    By akretowicz in forum John Deere Forum
    Last Post: 10-29-2011, 08:50 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
