Husqvarna YTH 2348 Mower deck will not engage
jwf1124
Husvarna YTH 2348 will run but mower deck will not engage. Replaced PTO switch and electric clutch. Battery is fully charged, all pulleys easily spin. Any ideas?
mhavanti
Check continuity of your wires from the switches thru the connectors and trace to the end runs. If there is lack of continuity anywhere in the circuit, your clutch will not engage.
Luffydog
There is another topic in the husqvarna forum that is titled the same thinking it might be same post as there with the same op with same issue as here.
jwf1124
Thanks for your reply. I have power going to connector to new electric clutch. Deck will still not engage. The tractor runs but mower deck will not engage. Could it be a faulty seat switch?
mhavanti
Sorry I wasn't clearer on the checking thru the connectors. Yes, check all your safety switches as well as making sure that the shifting linkage isn't out of adjustment and may have the reverse a bit out of kilter as far as that switch goes if it has that one. Some mowers don't cut in reverse without hitting the override switch somehow. Any of those switches may cause a problem.
Max
