Hello;
I have a Toro 20331 mower (this is the front wheel drive model) that has a bad engine, which I need to replace. The engine that came off of it is a B&S Model #: 124T02-0203-B1; Serial 08091156.
What I'd like to do is find a used engine to swap onto the mower. Does anyone know whether I have to have an exact B&S match, or can I simply use any engine that the shaft and blade/belt adapter fit onto?
Thanks much.
Thanks much.
