Results 1 to 6 of 6
  1. #1
    skiperkie's Avatar
    Join Date
    Jul 2018
    Posts
    16
    Location
    Florida
    Mower
    My XT1 Enduro Series Tractor starts but will not go forward nor backwards.
    My XT1 Enduro Series Tractor starts but will not engage forward nor backwards. The Cub Cadet is only two years old and I only have 45.2 hrs of operation on it. I do have it raised up but I have not idea what to look for. The belts to the deck seems OK. The deck blades do operate. I have a hydrostatic transmission. I am able to push the Cub Cadet easily forward and backwards.
  2. #2
    Join Date
    Nov 2014
    Posts
    11,475
    Location
    Australia
    Mower
    Victa slashers & Push , Rover Rancher II's, Cox ( several ) & White LT120 + GT 200
    Re: My XT1 Enduro Series Tractor starts but will not go forward nor backwards.
    If you can easily push it then the bypass valve is open.
    Twigs can catch the lever and open the valve.
    Refer to you manual about pushing the mower then go check the switch, all the way back to the tranny.
  3. #3
    skiperkie's Avatar
    Join Date
    Jul 2018
    Posts
    16
    Location
    Florida
    Mower
    Thank you for your reply. I did cleaned out any debris build up anywhere I saw it. I started the tractor while it was still raised up and I notice the back wheels had traction. I immediately shut the tractor off, lowered it and I began to mow the lawn. It was working. I came inside the house to update my thread when I came across your reply. I want to thank you, but I don't know where the valve is, in case this happens to me again. Where is the valve located?
  4. #4
    BlazNT's Avatar
    Join Date
    Apr 2012
    Posts
    6,973
    Location
    Missouri
    Mower
    RZ5424
    This is a picture of the bypass lever. It is attached on the right side of the rear end. Find the rod attached to it. It will exit the chassis somewhere normally the back. This should all be covered in your manual.
    Chuck
    We Do Not Stop Playing When We Grow Old
    We Grow Old If We Stop Playing
  5. #5
    skiperkie's Avatar
    Join Date
    Jul 2018
    Posts
    16
    Location
    Florida
    Mower
    Thank you Chuck. I read about the bypass lever and I did manipulated it back and fourth but the Cub Cadet did not move. Now I know that it was because the valve, which is operated by this lever, was clogged. Thank you. I learned something about my Cub Cadet.
  6. #6
    Join Date
    Mar 2019
    Posts
    Location
    New Mexico
    Mower
    Quote Originally Posted by skiperkie View Post
    How did you unclog this valve?
Similar Threads
  1. Replies: 1
    Last Post: 08-27-2016, 05:15 AM
  2. Replies: 3
    Last Post: 07-08-2016, 12:37 AM
  3. CC XT3 GS 42" Enduro series inquiry
    By RudyP in forum Cub Cadet Forum
    Last Post: 05-02-2016, 02:35 PM
  4. simplicity 6218 goes backwards in the forward gears
    By c9lb8 in forum Simplicity Forum
    Last Post: 04-17-2015, 05:10 PM
  5. MTD Lawn Tractor starts OK - won't go forward or reverse
    By Keith41 in forum Small Engine & Mower Repair
    Last Post: 11-26-2012, 09:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
