Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Join Date
    Jul 2018
    Posts
    Location
    Ohio
    Mower
    Re: need help with my v twin 16 hp
    Thanks for all the advice.Jump starting did not help.I put a meter to the battery,12.3 volts was the reading.Removed the starter,and put power to it,and it ran like a champ.And by the way my solution for removing the seemingly impossible right starter bolt was useing a metric Allen wrench to fit the torx head bolt.Removing the spark plugs did not improve the stiffness turning the engine.cleaned all my connections,still no luck
  2.
  3. #12
    1,000 Post Club
    Join Date
    Sep 2013
    Posts
    1,000
    Location
    Texas
    Mower
    Dixon ZTR, Kubota H1400, John Deere LX277, Yardman, Honda HR214, several Snappers with Honda engines
    Quote Originally Posted by slaghead View Post
    If the engine will not turn with the spark plugs out...my opinion is that there is catastrophic failure within the engine.
    Take drive belt off to take any load it is putting on the engine.
    Engine should turn with a wrench on pulley nut...not free spinning but with out hard effort.
    do others agree?
    What can he do to verify or eliminate major problem?
  4. #13
    Join Date
    Nov 2014
    Posts
    9,954
    Location
    Australia
    Mower
    Victa slashers & Push , Rover Rancher II's, Cox ( several ) & White LT120 + GT 200
    Quote Originally Posted by shiftsuper175607 View Post
    do others agree?
    Nope, you are right, if you can not turn over the engine with the palm of you hand on the finger guard when the plugs ore out and the belts are off then the engine is siezed and requires a strip down.
    Could be nothing worse than a pushrod fallen off and getting jambed into the cam or a major failure.
  5. #14
    Join Date
    Jul 2018
    Posts
    Location
    Ohio
    Mower
    Quote Originally Posted by Boudreaux In Eunice La. View Post
    Engine is hard to turn with a breaker bar ??????? Hmmmm seems like a hydro lock or a semi froze engine.....
    Pull the plugs and then try to turn it over........ If not then try the bar again.... If still hard you got a froze engine on your hands.... Mon Ami ..
    Let us know something ~!~!
    Thanks for the advice Boudreaux,I've decided to take it to be repaired.I'm not tare the engine down guy.I'll let everyone know in a couple of weeks what they find
  6. #15
    Join Date
    Jul 2018
    Posts
    Location
    Ohio
    Mower
    Sorry for the delay.My tractor was in the shop for a while.The problem was the electric clutch bearings were bad and causing the engine to seize up.thus the starter would not turn the engine over.Very expensive part.The electric clutch was replaced. $345.00 plus labor came to $425.00. Runs like a champ.Thanks for all the advice.
  7. #16
    Join Date
    Jul 2018
    Posts
    Location
    Ohio
    Mower
    [QUOTE=Luffydog;303457]Also could the electric clutch if has one.[/QUOTE You were right on. The clutch bearings were seized up
  8. #17
    Join Date
    Jan 2018
    Posts
    417
    Location
    Usa
    Mower
    Thank you for the update and letting us know what the problem was and the fix. Glad to hear you are up and running again yes the clutch is costly but not as bad as a new engine or a new mower itself in some cases its close. Glad to see your going like I said and thanks for the feedback.
Similar Threads
  1. 18.5 HP single vs 22 HP V-Twin
    By MaJaGo in forum Briggs & Stratton Forum
    Last Post: 06-08-2018, 09:20 AM
  2. Honda 18 hp twin
    By Mykey in forum Hustler Forum
    Last Post: 05-27-2017, 11:39 PM
  3. Buying Advice 23 hp Kawasaki V-Twin vs. 24.5 hp Toro V-Twin
    By asboothby in forum Toro/Wheelhorse Forum
    Last Post: 03-28-2016, 10:02 AM
  4. 17 hp twin 2 briggs
    By basstracker in forum Briggs & Stratton Forum
    Last Post: 03-28-2015, 09:12 AM
  5. 1999 bs 20 hp twin
    By diver00706 in forum Small Engine & Mower Repair
    Last Post: 11-09-2011, 10:55 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
