Repairs TB30R Clutch & Stalling Issues
cv2065
Hey guys. First time post. Hopefully you all can help me with my issue. I have a TB30R 30" riding mower. Just recently I started having an issue putting it into gear when cold. After it warmed up a bit, goes into gear fine but does jerk a little when releasing the clutch. Now when mowing, it wants to stall out every so often. I also think I saw a little smoke coming out from under the mowing deck. I was able to complete the yard the last time I mowed (3/4 acre), but not sure if it will make it this time around.
Seems like I've burned up the clutch, as I think that would cause it to stall as well, but wanted to get some second opinions before I go tearing into it.
Thanks!
