Mower deck Kubota zero turn Z122 bagging problem
pooba
I have a zero turn Z122 ebr 48" deck with a bagger on it. The question i have is anyone else having problems with this system. When I'm bagging there is a lot of discharge coming out the front right side of the deck and some little hay rolls at times. I think it is sitting on top of that angle iron they install for the bagger.. I have bought gator high lift blades to help. I know that when they put the bagger on there is a piece of metal in the front right for there bag system that i think is for a 42": and not the 48". The dealers are no help at all on this and if you want to talk to Kubota about anything its like pulling teeth ( service BITS). One of the other things that i have noticed is that the distance from the blade on the chute side has a big gap between the deck and the blade. Other than the bagger on this i love the cut and now that i made a stripper kit for it my grass looks good.
Thanks
