Hey, Folks!
Thanks and Kudos to BertsMobile1 for assisting me in getting my proper belts. Now, the problem I'm having is the blades won't stop spinning when the PTO is disengaged. I've checked the proper path of the belt and I did install it right. Any thoughts?
Thanks
BTW. I forgot to tell you folks that the machine is a Pro150 Walk-Behind with a 14 hp Kawasaki, mdl# 988088.
Thanks
