I've got a 2012 42" Pony with the 5 position deck height adjuster, and the absolute highest cut adjustment is 2 1/2" (in the top slot)?
I've leveled the deck, and checked for anything that looks bent, but don't see anything obviously wrong with the lift mechanism.
The new models I've checked look to have the same design, but the deck and lift part numbers are different...(changed in 2014).
Other comments on the web indicate this problem is common, with solutions recommended such as …...make up your own deck hangers, cut out a longer hole in the fender and re-position the handle notches, and get bigger tires?!?
Surely there is a better fix than that?
The lift handle on the newer models appears to be a beefier thickness, so maybe the handle is bent, but its shape is so convoluted, its hard to tell by looking.
Anyone else have this issue?
