Results 1 to 3 of 3
Thread: Which Zero Turn
  1. #1
    Join Date
    Jun 2018
    Posts
    Location
    United States
    Mower
    Ariens
    Which Zero Turn
    Looking for some advice from anyone with experience. I'm looking to purchase a mower in the next 6 weeks and ive kind of narrowed it down to the Hustler 54" Raptor SD $3999) , and the Bad Boy MZ Magnum 54" ($3499) (18" rear tires). The Bad Boy Has a Kohler Motor, while the SD has a the Kawasaki. I do like the heavy duty look of the Bad Boy, but i also like the bigger rear drive tires (20") and armrests of the Hustler.
    I mow about 2.5 acres weekly, mostly flat except for a few ditches and Septic mounds. Is the bigger rear tires a major plus? Ive heard they are better on hill, as in less sliding. And that they also may aid in a smoother ride?
    Any advice would be appreciatted.
  2. #2
    Join Date
    Jun 2016
    Posts
    164
    Location
    Connecticut
    Mower
    Hustler Raptor SD 54"
    Re: Which Zero Turn
    I have a Hustler Raptor SD, and it is a great mower. How is the dealer support for Hustler vs Bad Boy in your area. If the mower needs warranty work, that will be a huge factor. If you are buying from a big box store, know they do not repair the mowers they sell. Bigger tires mean better ride and less turf damage when turning.
    The RSD has ZT-2800 drives which is 1 step up from the EZT drives on the Bad Boy. EZT drives are sealed, so you can't easily change the hydraulic fluid in them. Fluid in the ZT-2800's can be changed. I feel the ability to change the fluid will allow the transmission last much longer. The RSD has a 3 year warranty, the Bad Boy has 2 years. Now you know why there is a $500 difference between the mowers.
  3. #3
    Join Date
    Jun 2018
    Posts
    Location
    United States
    Mower
    Ariens
    Re: Which Zero Turn
    Thanks for the info. I purchased the RSD, will pick it up next week.
Similar Threads
  1. Replies: 6
    Last Post: 06-20-2018, 05:16 PM
  2. 2013 hustler raptor zero turn wont start or turn over
    By wheel horse c-101 in forum Hustler Forum
    Last Post: 08-14-2014, 01:55 PM
  3. Replies: 3
    Last Post: 08-08-2014, 08:03 PM
  4. MTD mower won't turn left; will turn right!
    By cshafer in forum Small Engine & Mower Repair
    Last Post: 10-13-2013, 09:50 PM
  5. Scott ride on by john Deere starter won't turn over when I turn the key
    By Stenny in forum Small Engine & Mower Repair
    Last Post: 06-18-2013, 09:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
