Results 1 to 8 of 8
  1. #1
    Join Date
    May 2018
    Posts
    Location
    Virginia
    Mower
    YTH2348 Electrical Problem
    Recently when trying to start mower it appears dead but could hear clicking from engine area. Assumed it was starter key switch , replaced key switch but not case. Couple days latter it did start but few minutes later it would not start. Ended up temporarily bypassing seat switch by unplugging switch and removing jumper tabs. Again it starts and runs. Following week it won't start again! Hmm.. only thing left is brake/clutch switch, after i check it with ohm meter and actuate it a few times it starts, but i order a new one just in case. Low and behold yesterday back to same problem, replace the brake/clutch switch but still won't start.
    Battery volts 12.7. I did noticed that when turn key switch to first position that the hour meter is not on! any ideas, key switch checked ok via ohm meter B-A1
  2.
  3. #2
    1,000 Post Club
    EngineMan's Avatar
    Join Date
    Jun 2012
    Posts
    2,217
    Location
    South Wales UK
    Mower
    No mowers
    Re: YTH2348 Electrical Problem
    Check out the starter solenoid.
    "Information/Knowledge not shared will be lost for ever, I will give freely any information that will help you out, you don't have to take it, that is up to you...! and the word "thank you" will not cost you anything, so be nice sometimes and use it"
  4. #3
    Join Date
    May 2018
    Posts
    Location
    Virginia
    Mower
    shouldn't the hour meter display before i turn key to start position?
  5. #4
    1,000 Post Club
    EngineMan's Avatar
    Join Date
    Jun 2012
    Posts
    2,217
    Location
    South Wales UK
    Mower
    No mowers
    Don't the hour meter work when engine is running....
  6. #5
    Join Date
    May 2018
    Posts
    Location
    Virginia
    Mower
    yes, key switch has 4 positions, position 4 is start engine position, then you return key to position 3 or position 2 which allows you to backup with PTO switch on/Engaged and position 1 is OFF
    but hour meter is in direct connection with position 2 or 3. I'm going to disconnect all ground wire where battery negative terminates on frame, clean and lightly sand connectors and reconnect
    later toda
  7. #6
    1,000 Post Club
    EngineMan's Avatar
    Join Date
    Jun 2012
    Posts
    2,217
    Location
    South Wales UK
    Mower
    No mowers
    The hour meter comes form A1 on the key switch, if you have 12v there then yes it could a bad earth (ground) somewhere.
  8. #7
    Join Date
    May 2018
    Posts
    Location
    Virginia
    Mower
    FOUND IT !! Fuse not fully seated, voltage present but not enough physical contact to carry current of basic circuit before switch in motor start position
    Remember to check fuse seating on blade fuse even though you have voltage
  9. #8
    1,000 Post Club
    EngineMan's Avatar
    Join Date
    Jun 2012
    Posts
    2,217
    Location
    South Wales UK
    Mower
    No mowers
    Well done, and thanks for letting us know....
Similar Threads
  1. Husqvarna YTH2348 Electrical Problem
    By capnboink in forum Husqvarna & Dixon Forum
    Last Post: 04-02-2016, 07:31 PM
  2. Repairs Electrical problem
    By dennyandcarrie in forum Grasshopper Forum
    Last Post: 09-10-2014, 07:54 PM
  3. Husqvarna YTH2348 Electrical Problem
    By Zaklee in forum Husqvarna & Dixon Forum
    Last Post: 07-04-2014, 07:24 PM
  4. Husqvarna YTH2348 Electrical Issue
    By ESB in forum Husqvarna & Dixon Forum
    Last Post: 07-25-2013, 10:57 PM
  5. Electrical Problem
    By TarlsQtr in forum Craftsman Forum
    Last Post: 08-22-2012, 09:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
