Pully's
Tawana
Pully's for the blade turning belt are not supposed to wobble are they?
NO.
If the nuts have come loose then it will be new pulley & shaft.
If the bearings have collapsed it will be just a bearing replacement.
In either case leave the housing in the deck unless you decide to replace the entire housing as they rarely come off the deck without breaking.
